I have installed the above room stat and programmer, however the room stat overides the programmer, basically when the heating is not on the time for it to be on ( as normal ones work ) it comes on if the tempreture drops below the room stat set figure. Therefore the room stat calls for heat and it fires even when its out of programmed time. I have had both my electricians look at it and they both thought the product was faulty therefore i changed it for a new one and the same happens, there completely cluelss and theres no way it should happen. No doubt there is a very simple explantion but we dont have one. Has anyome else had this problem ?/? there appears to be no info on this issue online either
