Hotpoint Aquarius WD420 - Dryer issue
16 Sep 2010
Buckinghamshire
HELP! I have a Hotpoint Aquarius WD420. The wash cycle seems to be fine. However, when I set it to dry, it does the usual cycle for drying but doesn't actually heat up, so the clothes are still wet when I take them out. I've checked the manual and it doesn't seem to be any of the problems that the manual suggests it might be. Thanks
Check the heater /stat on The heater box.
If you are asking where to find it I surgest you find someone to fix it , you will need a test meter as well set to ohms. Remove the lid heater box is on top of drum.
