Hotpoint F-12 fault code
21 Nov 2009
Yorkshire
Hi all Hope you can help. I have a Hotpoint Ultima wt960 and a fault code of F-12 has appeared on the LCD can anybody inform me what this is? Thanks in advance
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty
Thanks Rocksy, Does that mean it's brain has gone then do you think? Best start to look for another!!
Cotty
what you can do is unplug it for 2 mins and make sure the connections on the pcb are tight if that dont solve it recon pcb needed or scrap it .http://www.emwelec.co.uk/ go here for a recon pcb.
