Hi all,
My washer dryer has come up with this error code, Reduce Creases - LED 2 flashing.
It does this about 1 - 2 minutes into the cycle.
I've been trying to work out whats causing it. From this site, i've found out that this means 'Pressure sensor stuck on empty', so I've tried the following:
- Removed filter from the drain pipe/pump, and cleaned out, found £1.25 and a button in there
- Removed clear pipe from pressure switch to drain pipe, cleaned it and tested for leaks
- Tested pressure switch by blowing into it. There seems to be three distinct levels, empty, intermediate, and high pressure. I'm not sure if the connections are correct, but there are definitly 3 levels
- Looked at PCB for signs of damage, found no dry joints or blown capacitors that I can see.
- Found that on starting a wash cycle, it starts to fill with water, but the drain pump is on too, and drains it all away, so the drum never fills with water. I tried disconnecting the drain pump, and the drum fills with water. I thought this had temporarily fixed it as the drum then starts to turn, but after about 1 rotation, error F04 shows up again
I'm really starting to struggle for ideas now. Any ideas what I can try next ?
Any help would be much appreciated !
Cheers
Cheers
