I think my heat exchanger is defective
My pressure in combi boiler remains quite stable but it leaks from the safety valve when the heating is on. When the heating is off the leak is barely noticable.
The pressure does rise slighty but I've never seen it get to 3 bar to activate the safety.
The wierd thing is I dont have to ever add any water
I've disconnected the filling loop so I know the filling valve isnt passing and letting water into the system.
The expansion vessel has been recharged to 1 bar and holds presure fine.
I've replaced all the diapragms, etc from a new service kit.
So I reckon there must be a leak in the heat exchanger allowing a small amount of tap water into the central heating circuit which in turn is leaking off through my leaky SRV.
Is there a way to test the heat exchanger without dismantling the boiler and should I buy a Vokera spare part or a pattern part at half the price at the same time I get a new SRV ?
I've stripped and cleaned the SRV but did read in here that once they let water through then it's best to replace them.
thanks
Webbie
ps: I remember a long time ago when filling the bathroom sink in the morning that sometimes there were small black paticles in the water. I havent seen them now for ages but could this have been a sign that the heat exchanger had failed
it's a Vokera Linea 28 (7 year old)
thanks
Webbie
