I need to put 40mm switch in a 30mm box
26 Mar 2010
Worcestershire
Am upgrading a few light switches around the house but the new switches are deeper than some of the boxes that are in situ.
For the surface mounted boxes then thats not a problem (just get a deeper box) but the those which are sunken into the wall is an issue cause I cant knock any more of the wall out to make them deeper.
Is there anything that you can get like a collar which adds depth to the box to take a deeper switch. Havent found anything on Screwfix :)
Cheers
Fair enough!
Just make sure you check your new switches first. Some accessories have square corners...
GPID_1100371221_00
and some have radiused corners...
The extension collar needs to match or it'll look awful.
Cause I would make a complete hash of it.
You'll get better with practice.
A couple of them are in a plastered wall and if I were to replace the box then I could balls up the plastered wall.
And then you can fix the little bit of plaster you damage.
But you're making existing holes deeper - you won't be attacking the actual plaster....
Crabtree accessories tend to have more out front and so don't need too deep a back box.
