Can anyone help with this: I have an Imi Powermax135 boiler which intermittently fails to ignite;it used to do this now and again after the water had reached temp. and needed to be heated again,but now does it when starting from cold as well.sometimes it does not ignite at all,other times it appears to partially ignite and goes through its auto cycle to try and ignite again after 10-15 seconds.Could it be a weak spark?The only way I can get it to fire is by continually switching between timed/cont and off on the prog.unit,which is obviously a right pain and is also causing me some large earache!!!!Does anyone know of a C.H engineer in Swansea area who services these lovely pieces of equipment?
