indesit WIL143s
6 Mar 2009
Cheshire
hi guys hope u can help me
my indesit WIL143s washing machine when i plug it in it powers up and all lights flash after a few minutes i can turn on and of with power switch but do no cycles
when i switch on the red light flashes constantly next to on button and also delay timer button and extra rinse button is also flashing
when i turn mains on and off all flash again
rang a washtech today and said it needs it reseting through a method difeerent to just unplug please help on advance
thanks guys
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty . new pcb needed try here http://www.emwelec.co.uk/
see below I have the f12 error - do I need a new motherboard - if not how do I fix it?
f16 N/A
So in this instance with the second light flashing the error code would be f04 light 2. pressure sw stuck on empty . new pcb needed try here http://www.emwelec.co.uk/[/QUOTE]
