hi - I am about to install new shower on the adjacent wall from where the old one used to be. Cabling and plumbing already there - just needed to re-route both to that wall - this is not a problem.
Walls is plasterboard.
What is the ideal position of the electric shower unit? I am planning to put it nearer to the corner so the shower riser will be in the middle. I read that the flexible hose should not reach the tray when it is hanging down - it appears the unit will need to be high up, possibly around 300cm from ceiling (ceiling is 2m high as is a loft conversion) Is this ideal position? (tray will be rised)
I read here that elbow compression fitting is preferred over the push fit type for connecting to the inlet connector - right?
Anything else i need to consider? Cheers
