We recently moved house and the plumbing system has been a night mare. When we moved in the water was off and when the wife turned it on within a minute or two it started coming out of the overflow. So during the move we turned the water on and off for a couple of days. We called a plumber recommended to us who kindly came to us on the 3rd day and fixed the issue after working out that the system had been drained down and the drain cock left open, so problem 1 solved. Problem 2. Hot water and central heating was supplied by a back boiler which would not ignite so he pulled it out and basically condemned it. We agreed to a new system going in at a cost of £5000. All well and then got hit by another unrelated bill. So we had just the boiler replaced. When the fitment took place and the filling of the system some bleed valves were seized so the radiators are air locked. Then two days later a connection on one radiator failed spraying hot caustic water over the lounge. So I shut the system down and called him out. He isolated it and came back the following day claiming British Gas had fouled up when fitting the radiator. There could be something in this as the olive was triangular as opposed to being semi circular. However this didn't ring true with me as to me it depends on the fittings used. Anyway, plumber came back had a look and said he needed a special part, isolated the radiator and said he would order it. 5 days later I get a text that he has booked us in to repair with the spare part then on the day he says he cannot obtain it. I msg him that from my box of bits I have something that would work but as is his job don't want to touch it but he is welcome to look at my suggestion.
1. I think this "engineer" underestimated the job.
2. Is it reasonable to expect an experienced engineer to pressure test the system and check bleed valves knowing it's an old system prior to filling.
3. Given that he didn't pressure test the system and a union burst within 48 hours is a call out charge reasonable even though he didn't really do any more than I did by turning the system off? All he really did was confirm the fault and why. He could have isolated the radiator but didn't and now want's another £150 for the call out and non existent repair.
I hope I'm not being too harsh with my criticism but I'm an engineer myself though in a very different field but at times not too disimmilar.
