Hi!
In the flat I've recently moved into there's a Sanivite 3 system which discharges water from the kitchen sink and washing machine into the exterior discharge stack, a distance of about 18 feet. For the most part the pipe runs horizontally under the floorboards, but it rises at a steep gradient about 12 inches under the window just before it joins the stack.
I've since discovered that the vertical run should precede the horizontal, not the other way round, but I can't figure out how this could be achieved in this situation.
The current system has been in place for years and clearly works, but the local authority has said it doesn't meet regulations. Needless to say there was nothing about all this in the home report . . .
Finally, the Sanivite unit is probably nearing end of its life, so I will need to think about replacing it soon. Does anyone have any advice or know of any pump systems where it doesn't matter if the vertical comes after the horizontal? Or if there might be some other solution.
Thanks for any advice you might be able to give.
