I'm planning on installing a peninsular kitchen worktop (standard laminate 38mm thick and 800x1800mm). The plan is to have it attached to a wall at one end (probably a 50x50mm batten) and just have two metal legs at the other end. Only the short (800mm) end will be against a wall.
I'm not planning to have any units under it and am worried that it will bow (or even snap) under load. It's just to be used as a breakfast bar area. Should I use more supporting legs or is there another way of doing this without extra legs? (to keep a cleaner look to it)
