Hi All
I am just going to lay a laminate floor in my L shaped hallway can someone tell me the best way to finish off the edges to cover the expansion gap.
You can either,,, remove the skirting in the hallway first. Lay the flooring then put the skirting board back. Or,,,,, Leave the skirting boards on then buy some purpose made mouldings that fix to the skirting after the flooring.
