How do I add a set of 5 amp light sockets to a room? It is to feed approx six 5 amp sockets for table lamps etc.
I assume I need 1.5mm cable? How should it be wired to a switch so that all the table lights can be turned off or on at the same time?
Where can I get the power feed from? I dont have access to the two existing ceiling roeses in the room, but I have access to the void above my hallway so could tap into the lighting circuit before it enters the room.
Is it ok to run the cable behind the skirting bord? (I already have a load of cat5 and ct100 wires there)
Thanks,
Ian
Thanks,
Ian
