I intend to put lights on the outside of my bungalow but on toting up the lights/wattage on the existing light circuit in theory I could be pulling 2400watts (11 amps?) if all the lights were on at the same time, (although I can`t envisage any scenario where this is likely to happen, only me and my other half live here).
From info gleaned from other postings and the "how to" section I think this is a problem and I should not run the new outside lights from this circuit. If so how much of a problem is it and how am I best to get round it and what is the best method for running the new lights?
On my CU there is a spare unused switch that has been switched off since we moved in two years ago. If the circuit is overloaded could I use this to spread the load and how ?
Can I run a spur of the ring main throuh an FCU for the new outside lights or what would you advise? The new lights are security type and will be 4 lights x 150watts.
Grateful for advice please.
