I'm having my units on stainless steel legs so I want some lights for under them- just wondering if there are any type of light that are good for this purpose. I guess I want the light to be as diffuse as possible.
Al
OK Im with you I think if I were doing this I would experiment with flourecent fittings, cheap to buy & run. You can spray paint the tube to give you a colouring (a light spraying) again its about trial & error.
This could be an area where LEDs might be useful! Perhaps fabricate a length of wood containing ultra bright LEDS of your chosen colour.
If not, a few fluorescent strip lamps. If you want the emitted light to simply stay under the cabinets, mount the lamps on their side, with the tube towards the back. If you want the light to spread across the floor, mount the lamp at the back, with the tube facing forwards.
Beware you will see imperfections in your DIY floor tiling if you do this!
