loft insulation
26 Dec 2005
Hi
I have just moved into a house where there is a great quantity of carpet remnants. Is this OK to be used as loft insulation between the joists?
And a supplementary question if I may...
when adding timber to raise the joists to allow deeper insulation...should these be along the exisiting joists or at right angles to them?
Also the previous occupants left behind a stack of polystyrene ceiling tiles..could these be broken up and used as loose insulation material..or would this be a fire hazard? is polystyrene ever used as loose loft insulation?
thanks
reg
_________________________
Lynda, moderator
please note forum rule 20, your post has been split
err..personaly.. and im all for not doing things the "normal" way... i wouldnt... thinks what happens in a fire, all that dripping molten plastic raining down isnt a nice prospect! rather use the carpet as undelay/insulation between the floors of the house (if its awful and you dont want it seen) or stitch em together to make a patchwork carpet.... and id dump the tiles if they are of uncertain age they might be the napalm burning sort!
regvarney said:
Hi
You could do, if you're fond of wildlife. It will make a great home for mice, and insects including carpet beetle and clothes moths.
However, it won't be as good an insulator as fibreglass mat, and it will be a lot heavier so might pull the ceilings down.
JohnD said:
regvarney said:
Hi
" I hate you, Butler"
