I have a memorial plaque which I want to mount onto a suitably sized piece of concrete, such as a 12" square paving slab. It is to be used near a grave.
I bought a 12" square paving slab and set about mounting the plaque, but I split the slab I think because the screws were too big for the holes. They tightened up after not too long, then got easier as the crack developed.
Is this the right way to do it?
I was using a straightforward paving slab, 1 1/2" thick or so. Drilled it to 5.5mm then used the red rawplugs. Maybe I should have gone to 6mm or the brown ones and 7mm
