I have just moved into my new home which has a micro-bore system.
I wish to replace at the v.least the tails connecting the radiators to the system since the micro-bore connection looks rather ugly (especially were the pipes first exit the floor, run about 30cm along the wall before the first edge of the radiator)
Apart from that they are causing me problems since I want to replace the skirting too but the pipes are in the way.
My questions:
1. Can I add 15mm ends and connect to the 8mm pipe under the floor boards (reading around this appears to be ok)?
2. What is the maximum 15mm end I should consider running from the 8mm without adversely effecting the systems flow/balance?
3. First time doing any pipe work so what will I need other than flux, solder, gas torch, 15mm pipe, 15mm to 8mm reducer and pipe bender?
4. If i get cold feet how much is a plumber likely to cost / would they do this?
Many thanks.
My questions:
Many thanks.
