Mira Sport problems?
23 Jun 2006
I've got a 6 year old Mira sport 7.5kw that can only lukewarm at best.
Even when its on its on the hottest setting its still not good enough. The pressure seems to of dropped off even though it was never great.
Is it a case of replacing the whole thing or do mira supply parts to correct these problems?
My shower........is in your hands :cry:
6 years old I guess your heating element has scaled up like your kettle would.
Time for a new shower.
Pete
I guess mira sport are'nt designed to have the heating element replaced then?
If its got to go, any recomendations for a replacement? Something with a bit more pressure?
Cheers
Mira are an excellent range pressure is down to what your supply pipe provides.
You could upgrade to a 10.5kw shower as long as you elec cable is 10mm
P
Is it worth contacting mira to check on replacement parts?
There is a low pressure light on the shower which is not lit, so i thought the pressure must be ok?
Also would the upgrade to 10.5kw make much difference.
Thanks for the advice
For the cost of replacing the element to a new unit not viable.
10.5kw hotter and more flow.
Low pressure light only shows minimum pressure.
p
