Hi everyone
Under very high rainfall, we have a problem with water getting into our basement. As the house built on a slope, the front of the house is two storeys, whilst the back is three (with access to the basement). The leak occurs through the cavity wall at the back of the house which is not surounded by any earth.
Anyway, I think I have tracked the problem - outside the house near where the leak always occurs is a drain which takes water from the kitchen sink (and dishwasher) and roof. After digging today, I have discovered that the pipe is an old salt glazed pipe. Where the pipe meets the drain U bend, there is some mortar missing around the collar. The water slowly drips under normal conditions but when more water is added via the sink, it leaks quite substantially.
As there is no crack in the pipe, I intend to repair the missing mortar around the collar but was wanting to check:
1. What is the correct mortar mix to use and is it simply a case of pushing the mortar back into the collar where it is missing?
2. Is there are more suitable fix e.g. some sort of silicon sealant?
Thanks for any help
Thanks for any help
