Good evening all.
I have recently moved into a house and have absolutely no idea how all this central heating stuff works. I would grateful if someone wouldn't mind taking 5 minutes to assist me with the following questions. The system I am led to believe is a standard gravity fed setup, consisting off:-
Glowworm Ultimate 50FF boiler
ACL LP241 Programmer
ACL Drayton RTS2 Thermostat
Gledhill hot water cylinder
12 radiators (without thermostats)
My questions are as follows:
a) With the LED on the RTS2 on ("call for heat" on), is it normal for the boiler to not be on? Sometimes it only fires up for a minute or so and then cuts out again, even though the LED is on.
b) The thermostatic knob on the boiler itself is currently set approx mid-way between min and max... is that correct?
c) The upstairs of the house gets very warm, however with the room thermostat on 22 degrees downstairs, it seems to always be "on" and never reach the required temperature. Downstairs is always noticably colder. Is there anything I can do to alleviate this?
d) There is a tap on a pipe from the bottom of the hot-water cylinder that is neither on or off. I am told this is to balance the flow of the water between the heating and the hot water. Is this correct? And if so, how do I know when its at the correct setting?
I really appreciate any help that anyone can offer.
Thanks in advance,
Steve
Thanks in advance,
Steve
