multiple flood lights
29 Oct 2011
Kent
I want to hang three 500w flood lamps to light a stage. Can I spur off of a socket ring and switch on with one fused spur switch? Comments please.
In theory yes - provided the appropriate cable and connectors is used, and the lights have a suitable front guard to prevent failed lamps exploding onto the stage, and you have a suitable way to hang these including safety chains, and the lights are of a type designed for use indoors without causing the surroundings to be overheated. They will also need to be tested before use to ensure they are wired correctly. There is also the issue of ridiculously short lamp life, and who/how the lamps will be replaced on a regular basis.
Unless this stage is in your own home, there will inevitably be other regulations and requirements to comply with.
Far simpler and probably cheaper to just buy or hire the proper stage lighting.
Problem is proper stage lights are very expensive. This seemed a cheaper and effective option for occassional use. The lights will not be directly above the stage.
You can get a Par 56 can for about a tenner, and a lamp for about another tenner. Surely £20 isn't too much?
Try here
It's not worth messing around when you can do it properly for not much more than you're planning on spending.
Try here
Hey Thanks, didn't know about them.
Do you think I should use an FCU per light, or would one switched be enough?
Try here
Any benefit using a Par 64?
Try here
PAR64 is just a larger lamp and will give a wider spread of light.
It's up to you.
One FCU would be able to power the lights, but 3 seperate swithces gives you more control.
Is there no existing wiring at all to this stage?
It's up to you.
Nothing, the staging blocks sre only put out at christmas time.
Where are they put out?
When they are out, do any people get up on them and do things?
If there are people up on them doing things are there any other people in the vicinity watching them?
