Hi all
Suggestions welcome for the following problem.
Moved two rads on ground floor,extending 8mm pipework, having drained down the whole system. After refilling, water is not heating up as it should i.e. no domestic hot water, unless immersion is used.
System is open vented gravity hot water and open vented pumped central heating, gas boiler. Is the problem most likely an air lock? How important is it to bleed the circulating pump, cos it is in a most inaccessible position.
Thanks in advance of any advice
