Noisy Hot Tap in Bathroom
8 Oct 2008
Midlothian
New combi boiler resulted in high hot water pressure which required strength to turn off the tap. I replaced the washer and this cured the problem but a new problem appeared...........The tap squeaks noisily at a certain revolution of the tap......Can this irritating noise be cured?
Your taps are probably low pressure ones, change them for high pressure taps
