Hi, we had a new boiler system fitted with its pressurised setup that does away with a header tank, replaced with a red sphere shaped bottle thing. We get regular loud moaning from pipes when running cold or hot taps at high flow. The pipes vibrate in the airing cupboard, so it's a bit like water hammer i guess.
The moaning can go from a few seconds to 10 seconds, and just afterwards we hear a rushing water noise, like the water is finally getting through the system somewhere. We put up with it for about 14 months, but it seems to be getting more regular now, almost every time we run the taps anywhere in the house.
I assume it's an airlock somewhere that clears after the few seconds?
We have to regularly keep an eye on a pressure valve in our airing cupboard, and we are able to turn two taps to let water into the pressurised system. I think that's how the plumber put it!
We had a problem with water hammer in a downstairs loo, but i fitted an in-line isolation valve to the cistern, and have adjusted the flow so that it fills slower, but we get little to no hammer noise anymore.
Help very much appreciated.
Cheers, Tony
Cheers, Tony
