Oil pump solenoid testing with a Multi Meter - Help!
9 Sep 2012
Oxfordshire
Hi, Can someone please 'in simple terms' advise how to test an oil pump solenoid valve incl. the expected ohms reading, as im getting in a pickle with it? many thanks Simon
Need a lot more information.
What do you want to test ? the function or the quality of the solenoid ?
The resistance will depend on how the coil is wound, the voltage and the wattage of the solenoid.
An a.c solenoid will have a fairly low dc resistance as it's inductance will regulate the current drawn. A dc solenoid will have a resistance that equates to it's power rating worked out from V²/P.
