- Joined
- 22 Jan 2008
- Messages
- 2
- Reaction score
- 0
- Country
Hi there,
In 2006, I fitted a new kitchen, and while I was at it, I tidied up and made some changes to the wiring [detail: extended the ring main and added extra sockets, wired in fused spurs off the ring for below-worktop sockets for W/M and D/W, re-routed the cooker circuit so that the isolator switch was not over the gas hob, wired an extractor into the cooker circuit - using appropriately rated cable, etc]. I'm confident I followed best practice for these alterations, and was happy in my own mind that I did a safe and competent job. As far I know, the only non-compliant part of the work is that I used old-colour cables (black/red).
HOWEVER, when I untook this project, I did not know that this work is now controlled by Part P of the buidling regs, and that it should have been carried out someone who could issue the relevant paperwork. Or alternatively that I should have notified the building authority and had it signed off by them.
I realise now that I have made a first class blunder, and unfortunately, I have only realised this as we are about to sell our house. I don't want to waste our buyer's time, and don't want to give them misleading information. So can anyone help me with:
1) What questions are likely to be asked by the buyer's solicitor? Will the question be as specific as "have you had any Part P electrical work done? Do you have the cerftificates". In which case, I'm in big trouble. If there are no questions about when jobs were done, then this work could have just as easily been done prior to part P.
2) Is there ANYTHING I can do to retrospectively get this work checked and signed off? Will a friendly electrician take pity on me and inspect my work and produce the paperwork if he approves it? Will a full electrical safety inspection give validity to all of the wiring in the house (assuming it passes)? The only problem with this latter solution is that my house has oldish (1970s) wiring, so the fusebox and earthing is dated and likely to flag up other problems for the buyer.
Feel free to chastise, condemn and generally give me a hard time for my stupidity. If you could footnote this with any helpful suggestions (preferably not: rip out the kitchen and rewire it) then so much the better.
