I have had a PIR done with the following results;-
1. No cross bonding to boiler C2
2. No cross bonding to Kitchen Sink C2
3. No cross bonding to bathroom C2
4. Double Pole Switch in Kitchen for Fridge has no earth screen or grommets to cable entry C2
5. Lights to Kitchen have connectors C2
6. Neutral from the Meter is larger than the rest C3
7. Intruder alarm supply cable earth stops at Junction Box C2
8. No warning stickers to Distribution Board C2
9. No box to Earth Stake C2.
I have repaired items 1 - 5 myself as below;-
1. Fitted clamps to all copper pipework under boiler, linked with 10mm^2 Earth Cable.
2. Fitted Earth clamps on hot & cold supply. Linked with 10mm^2 Earth Cable.
3. Found 4mm Earth cable ran from shower CPC to earth clamp on bath cold feed. Added clamp to hot feed and both radiator pipes (under the floor). Joined with Earth Cable.
4. Fitted Grommets & replaced short feed cable. Fitted Earth sleeving.
5. Fitted replacement light fitting. Used junction box in the loft space and ran a new 1.5mm^2 T&E to the new fitting removing old choc block connectors.
For items 6 to 9 I have been quoted £110 + VAT. Does this seem a fair price? Also are any of these simple enough to be completed myself?
