Hi, I will eventually be putting up new stud walls around the bathroom. When I get everything else sorted first! I will be installing a 1200 shower unit and base but prioer to that I will tile the full wall onto aqualpanel for equal to the are af the shower eclosure. However the rest of the bathroom will be half tiled and the top half of the walls will be new plaster finish. My question is because these tiles are 600 x 300mm would I be best to continue with the cement aqualpanel around the bottom half of the walls to hold these tiles and if so whould I just have normal plasterboard on the top half for the plaster finish?
Second question, the tile board and plasterboard will meet neaty level surface to each other about the middle of the wall creating a nice even playing field. Do I tile first then get the plasterboard skimmed down to the finished tile line and then affix a tile edge or what is the proper way to do this?
Johno
Johno
