Plaster, Paint, Wallpaper
14 Oct 2005
Glasgow
afternnon all
Recently converted the garage into a new room, the walls are plastered and the first coat of diluted emulsion is on. However the wife now wants wallpaper on one of the walls.
Can I now wallpaper directly onto the wall or would I need a second coat of diluted emulsion to ensure the walls are sealed and if I do wallpaper should I line the wall first, I know it's new plaster but a decorator told me it would be easier to remove the paper at a later date if lined.
Thanks for your help (in adavnce)
Cheers
Michael
Your first mist coat should be adequate for papering. If you've got a good finish on the new plasterwork I wouldn't bother lining unless its a very fine finish paper you're using.
If you ever want to strip the paper it'll go back to the mist coat layer so in this case lining is irrelevant, unless you are going over the lining paper with eggshell or similar....... at which stage we're in the realms of "why?"!
Hi guys
Thanks for the info. I did give the wall a second mist coat, just to be sure. I will remember and size prior to wallpapering as the wallpaper itself specifies pasting the walls and then apply the wallpaper. Not approached wallpaper using this technique before is there anything that I should watch out for i.e wall drying out to soon, the paper isn't as flexible in movement, etc
Cheers for the help :)
M
The mist coat should act as the size ;) You have the paste the wall paper. It's easy, cut your lengths ready, paste wall enough to cover width of paper, hang dry length strait away, dont worry about the paper being inflexible it soon becomes so, paste next area and so on.. Its a doddle.. But a pain on stairwells :oops:
