Ok guys just built an extention on the side of my house,now need to finish the walls on the previous outside wall which is now an internal wall.Plan is to dot and dab plasterboards do i need to prime walls first with pva or is it ok to go straight onto wall
what is the base on which you will be dabing onto. if it was render and you have hacked it off then it might be worth dusting down and pvain first just to make sure your not just dabbing on to dust but anything else will be fine just to dab straight on to.
