Plastic or copper pipe for radiators in concrete floor
7 Sep 2008
Essex
Hi
Am new on this site and am unsure as to what heating pipes would work best -am building a new kitchen extension and am planning to lay the concrete floor next weekend-will have one radiator in the extension -my query is whether I can useplastic pipe rather than copper and bury this along the side of the wall in the floor-
If I useplastic pipe,does this need to be protected by an exterior plastic tubing - or is it OK to put this straight into the floor before I lay the concrete - advice would be appreciated here as I am a novice- ( for my reasons I woudl rather useplastic than copper -
Tony
for water pipes it's fine just to use plastic but test the pipework before laying in concrete. Gas can only be copper or tractpipe (and protected).
Dangermouse
Thanks for your reply - looks like I will be using plastic pipe as its for water heating system for radiator
Do I need to protect the pipe with exterior tubing or not ?
Cheers
Tony
No you don't need to protect the pipe in any way although it is a good idea to apply aluminium tape to the surface to make it detectable with a pipe finder. Adding insulation to the pipes is also a good idea, although not absolutely essential, but it'll stop the heat warming your floor rather than the room.
