Anyone seen one of these before?
Its in the kitchen of a house I'm quoting on. If you can't tell from the picture, its a standard fluorescent fitting which is then plugged into the bayonet light fitting.
My initial thought was that it would no longer comply as I understood plug in adapters were generally frowned upon, but then the argos site has this which seems to be a more modern replacement.
Given that I now see no reason to insist/suggest it is changed (apart from aesthetic/taste reasons )
Anyone disagree? I will see if I can open it and inspect the internals but given an insulation resistance test is unlikely to do it much good is there any other test that I should be doing on it?
Gavin
Gavin
