need help new to the plumbing game my central heating system is a potterton puma one radiator is,nt working both inlet and outlet pipes cold took the radiator off to check the flow plenty of water coming out of the inlet very little out of the outlet could there be a blockage in the outlet pipe if so how do I drain the system if need be or can I put an isolating valve on the outlet pipe so I can work on the blockage trouble is I can,nt seem to get hold of a 10mm vale appreciate any advice.
regards Denis
regards Denis
