Any help or advice please.
We are installing a pond at the end of our garden.
To put a supply of electricity to the pond pump & filter we have bought the following:
Weatherproof Switch Box 4 Way - (according to the brochure - Ideal for pond pumps and aquatic equipment. Fully weatherproof, 4 switched outputs (750W + 3 x 250W). Individual power-on indicators and integral mounting plate. )
1.5mm 3-Core SWA Cable 25m - (according the the brochure - 25m. BASEC approved 3-core (6943X) galvanised Steel Wire Armoured Cable. Black PVC sheathed. Harmonised core colours.)
Gland Kit Ext - Suitable for SWA and PVC cables. BS 6121-1. - Kit contains 2 glands, shrouds, lock nuts and earth tags.
RCD Adaptor - A quick way to protect many tools. Prevents electrocution from damaged cables. 13A max load. Trips at 30mA. Active operation.
OK - right now the next part and what I actually want to know:-
ONce we've fitted in the pump/filter etc we will wire in the weatherproof box.
Weatherproof box to inside house using SWA cable.
SWA cable to electricy supply ? We would ideally like to just plug into a plug socket rather (using the RDC adapter) than into the main electricy junction box. What will we need to do to attach to a plug onto the SWA - from what I have read online I assume we can't just attach the plug onto the SWA cable - what will we need to do?
Is there anything else I should be doing?
We will most probably get a sparky in to double check everything, but wanted to get most of the leg work done beforehand
I'll try my best to answer any questions
