Good Morning
Last week I called BG out as the rad in the living room and bedroom were both cold. I would bleed the system and air/gas would come out however the gas would make a return withing a day.
BG informed me that rust was causing this build up of Hydrogen gas in the system and what is best is a power flush. After doing some research I found that the £670 quoted by our friends at BG was on the steep side. This quote does not include a MagnaClean system being fitted, that was another £150.
I am looking for some advice please if the it is worth getting another (cheaper) firm to perform the PF of if I will get the same results by draining the system and adding the Fernox DS-40 to the system.
I guess i need to get a plumber out to fit the MagnaClean.
Any advice would be great.
By the way I have a BAISI M90E Combi boiler (2 years old) with 7 radiators and a heated towel rail.
Nuno
Nuno
