yellow is not signal strength its signal security.
In ricochet diagnostics you will see a numerical value for signal security.
it may improve if you run it again (if it was started before everything was in place), and I would be in engineering but yes you can do it as described.
However to improve signal security you would need to add more devices normally.
more devices to ricochet off.
