Hi
I wonder if somebody can help. The diverter valve was leaking, so the engineer replaced this. Since then, try as he may, he cannot get the bolier to fire up. The green light on the very left is blinkiing once every 2 secs, and no other lights are ON or blinking. The pump comes on, but the fan (and the ignition) do not. He spoke to the technical people at Biasi, and they suggested checking the voltage across the two PCBs (the one on the right is Honeywell). The voltage on the left is 240V, but as soon as he plugs the cable into the right board, there is no voltage. He has replaced both the boards and the temperature probes. There is not much else left to change.
Pressure at 1 bar, external T/stat.
Can anybody help? Many thanks
