Recently the door contact isn't registering when the alarm is set...
If I type in the code and leave the house there is no change in the sound from the keypad, and when you come back in the house, the keypad doesn't beep to get you to disarm the alarm but will go off if you pass a PIR.
I did a walk test and all the PIRs are recognised but not the door contact.
Do the magnets go bad or can the unit on the door frame with the wiring go faulty? I can't see any moving parts but don't know how they work.
There has been no other work in the vicinity that may have nicked the cable, I'm a little worried that it may be the pcb.
