Good morning,
We have been having some problems with our system. A couple of times recently the heating has been on happily, both downstairs and upstairs circuits, plus hot water. Then I've noticed the radiators going cold. When I checked the boiler, it was making a normal amount of noise but had no flame. Turning the thermostats up or down made no difference. A green light was flashing 2 times a second ( it is normally slower) but not as fast as 4 times a second which the manual says is a fault code. No lockout light was on either and the pressure was above 1 bar. If i turned the system off on the electronic timer in the kitchen and then back on, the system fired up straight away and it came on normally this morning as well. I'm a bit of a worrier and wasn't sure if the boiler operating without a flame might lead to any serious problems like gas buildup. We have been having some loss of pressure over the last year but the expansion vessel was repressurised and the loss has slowed down (I realise this needs sorting too). Any thoughts?
