Hi
Im going to put a DPM down, 100mm Celotex then screed on top (probably another 100mm) with Chicken wire placed down to help avoid breaking.
My question is could I make a frame to create a channel in the screed to run the radiator pipes along, rather than just immersing them in screed?
I could then run the pipes under the "floor level" (will have laminate on it) and still have future access "if" required
Would than comply with Building Regs - pipes will be insulated
