Hello can you help me?
I have a leak in my bedroom (upstairs) I want to stop the water getting into that radiator and still use the central heating system for the rest of the house (will freeze if I don't lol) I have a combi boiler system (no tank)the worchester 24i model, I have turned the water off by the stop cock (under the sink) but the water is still pumping through the radiators why how do I stop the water. The radiator "ONLY" has one valve thingy to turn but this does not turn the water off to it...it just controls the heat (looks like a small white tube with 4 slim grips around it, don't know if this helps) which is on the left hand side of the radiator but nothing on the right. On the rightside of the radiator is where the water is coming through but there is nothing to turn there just the bend from the floor to the radiator...how do I stop the water coming through with out unbolting everything and getting water everywhere? I have drained the radiator after turning the stop cock off (was told to do this).
