Radiator problems
19 Jan 2005
Hi
Just had a new boiler installed (Glow worm 80hxi) using the gravity method. The radiators were not changed
I have hot water, plus all the radiators upstairs seem to work okay - but downstairs - out of 5 radiators, one gets hot, 2 are lukewarm and two are stone cold
I have bleed all the radiators so that water dribbles out - and also turned the screw on the pump until water dribbles from that too - All pipes into the pump feel hot
Anyone know what the problem is & what to do ??
Many Thanks
Archie
I assume you mean open vented not gravity, if pump bled ok, airlock most probable. Did you install it, if not then get the installer back.
Get the installer back to sort this out. The installation of a new boiler is not complete until whole heating system is working at least as well as before.
