During the renovation of our house, we had two of the radiators that were removed from our second floor installed in the basement (temporary heat until the HVAC for the first floor gets done in the Spring). All of the second floor radiators have been disconnected. The first floor ones remain and work perfectly. The two in the basement were tapped off the main loop from locations that formerly served the second floor. We've bled them to no end. We've confirmed that they are not clogged. We've determined that the mono-flow valves on the source side of the radiators don't seem to be forcing water through the radiators. In fact, it appears that the water is trying to flow into the radiators through the return pipes. Consequently, the water doesn't seem to be flowing through the radiators at all, since there's pressure from two opposing directions. Any thoughts
Would a backflow preventer on the return pipes help this?
