Ravenheat HE85(A)T Combination Boiler Burner On/Off
4 Dec 2008
Norfolk
Can anyone help...What part needs replacing and what test can be carried out....
Problem
Deman for Central Heating (CH), Burner lights, for 3 sec, reduces flame for 3 sec, then turns off, then starts trying to light again.
If DHW turned on, wait until water hot from tap, turn off DWH tap, 3 way valve turns over to CH, burner keeps on until water hot enough, then starts the problem cycle.
Settings are;
Inlet gas pressure
Static no flow - 21 mbar
Full gas flow - 19.5 mbar (10.5mbar at burner)
CH Demand
Signal to modulator - 5volts no gas at burner - Burner off
Signal to modulaor - 20volts 4 mbar gas at burner - Lights & stays on for 3 sec
Signal to modulaor - 16volts 2 mbar gas at burner - Lights & stays on for 3 sec
Signal to modulaor - 0volts 0 mbar gas at burner - Burner goes out
DHW Demand
rises to-
Signal to modulaor - 34volts 10.5 mbar gas at burner - Lights & stays sec
Recycles ok
Many thanks to those that can help......
Sounds like another fan PCB failed!
Although you have described it rather differently from most people.
Tony
Tony,
Many thanks for the help, it is very much appreciated........
I also hope this request for help and your answer will help others.....
I will post a reply to let you know how it goes....
Once again many thanks...
David.
Hi All,
Replaced Fan Modulating PCB, burner now stays on when CH requires heat.
:D Once again many thanks to Tony for advice.
David
