Hello
I am replaceing the basin and pedestal in my bathroom as part of a revamp, but I want to install the new basin about 10-20cm to the right of the existing one, to provide a bit more space between the bath and the basin.
The existing basin is connected to the water supply by two vertical copper pipes that rise straight up out of the floorboards, so these would need changing somehow if I want to put the new basin in a slightly different position.
I am redoing the vinyl floor tiles as part of the renovation, so have no problem with getting under the floorboards.
I am not skilled enough (nor have the required tools) to solder pipework, so I am thinking of compression or pushfit plumbing.
My first question is... should I consider making the alterations to the existing pipework below floor level, so that the pipes then rise from the floor in the correct location? I think this would look much neater, but potentially be more problematic in future years if there are any leaky joins as access would be difficult.
Secondly, and probably more importantly, what are my options for changing the pipework so I can plumb the new basin in a different locations? I'm thinking...
- Put some corner/L shaped joins to create a 'dog-leg' in the pipework, using compression joins and copper pipes
- cut off the existing copper pipes below floor level and attach flexible metal hosing up to the tap connectors.
- cut off the copper pipes below floor level and use plastic push-fit or compression joins, and then flexible plastic hosing to the taps
I plumbed in a new kitchen last year so I have some basic experience with plumbing but far from profficient, so really i'm a bit of a beginner at this kind of DIY.
Many thanks in advance for any help you can offer
Tom
Tom
