I have installed a set of bifold doors that are in a double thermalite cavity wall with a 4m long catnic steel lintel above. The doors are set back around 2" from the outside of the blockwork so I should be able to fit a corner bead down the verticals. Question is, how do I do the horizontal edge above the doors and render under the steel lintel. also where the render meets the aluminium door frame do I simply render to it or fit a stop bead just off it to allow for some movement?
