Hi all, was hoping someone more knowledgeable than myself (which is probably most of you!), could advise me on the best approach here:
I need to lay a concrete slab in my living room, have been advised to lay a minimum thickness of 4inches, which adds up to a total volume of 2 cubic metres. Problem is access is between 2 houses and the driveway is only 8'6" wide at it's narrowest point. I rang round a few local ready-mix firms and the narrowest vehicle they had was 8'2", so I doubt they'd be able to get in without causing a major standstill on the main road that they'd have to be maneuvering in from.
Is it worth ringing a few more places, or is about 8'2" the narrowest I'm likely to find?
Alternatively, there's a road running along the back of the house, and I have a 5x7" air brick in the back wall that can easily be knocked through, about shin height on the exterior and head height inside, so I was wondering if it might be possible to funnel the stuff into the house through such a small hole. Anybody have experience of doing this or am I going to have to face the fact that mixing by hand is my only option? I didn't seem to be able to successfully explain that on the phone so thought I'd be better off asking here than continuing to confuse people over the phone!
It seems that the materials alone for mixing it myself are going to cost more than ordering a batch of ready-mix, and then I'll have to cart over 5 tonnes of cement and aggregate 50 yards to the house from where they'll have to drop it off before I even get started on mixing it, so if at all possible I would prefer to have ready-mix delivered. From the research I've done though I think I'd be better off mixing it by hand than having them pump it in because the main restraining factor is money!
Any input would be greatly appreciated.
