I need to make 17 trusses for my timber workshop (10m long building based on 600mm centres). The trusses will span 3.4m and have a 18 degree pitch
i've made a jig to cut all the wood angles but i'm still abit unsure about the best method to join them all together.
Would it be ok to use some nail plates such as these
http://www.toolstation.com/shop/Str...ised+Nail+Plate+80+x+150mm/d210/sd2797/p25743
or would i be better making some plywood gussets? and if so what sort of thickness would i be needing.
cheers for your help
Matt
Matt
